Hi Team,
Customer want to know if they PGA900 could act as a Master and collect data from an external sensor. Below is the details.
I am using PGA900 to read temperature data from an externally connected sensing element.
At the moment, I am able to access this data using SPI with the help of a microcontroller.
However, I would like to connect a additional Humidity sensor to the PGA 900 so that, I want the PGA 900 to read humidity data from the external sensor and can use it to perform humidity compensation inside the PGA900 only.
I would like to know if PGA900 could act as a Master and collect data from an external sensor
Thank you in advance. Cannot find any information regarding this kind of application in our part.
Maynard
