Would you be able to help advise the B channel status when TMUX1574 from TI is connecting between D and A channels? Is the B channel in HIGH-Z state?
Not able to find this in the datasheet.
Thank you,
Thank you,
Hi Robert,
When the EN/ = L (0), SEL = L (0) and the SxA pins are connected to the Dx pins, the SxB pins/Channels will be Hi-Z as the switch connection from SxB to Dx is turned-off. The leakage seen by this pin will be close to the IS(OFF) leakage as mentioned in the electrical characteristics table.
Hope this helps.
Thank you,
Sandesh
