Hi Team,
What is the EN threshold voltage of the 1309 chip? , the voltage value below which the chip is turned on, and the voltage value above which the chip is turned off
Hi Team,
Hi Amelie,
Please refer to the VIH section corresponding to each VDD below to see what the minimum voltage is needed to turn the device off (for the /EN pin as this is an active low device) and the VIL section which shows the maximum voltage that can be registered as a low input (turning the /EN on, voltage needs to be less than this value to turn the device on):
Thanks!
Bryan
You are welcome Amelie. Let me know if you have any other questions.
Thanks!
Bryan
