TS3V713EL: Pin 8 connection
Part Number: TS3V713EL
Hi All,
May I know whether we can input high level voltage on Pin 8 (N.C pin) of TS3V713ELRTGR?
Could not found related information in the datasheet.
Thank you.
  • Hi Chia,
    We recommend that all N.C. pins (no connect) be left floating since there is no internal electrical connection. I know some engineers must follow a standard for their design of no floating pins. If this is the case, simply GND the N.C. pin.
    If you can't work around high-level voltage present on N.C. pin, then it should be fine inputting VIH < VDD since no internal connection is present.
    Please search on the e2e forum for commonly asked questions. Your question was also answered here in a previous e2e post.
    Tyler
