Other Parts Discussed in Thread: TMUX646, TS3L500
Hello!
We need a 2.5G Ethernet port for switching. The schematic diagram is as follows.
The test found that after two change-over switches, the 2.5G signal could not be switched to RJ45. It was OK to remove the switch chip and directly weld RJ45. The TS3L501E switch chip was used. The following signals were all after the transformer
Does TI have any similar design or IC recommendation? thank you!!
