Team,
Customer would like to check the reflow data for SN74AUC2G66DCTR since it is not provided in datasheet. Appreciate your help.
Team,
Hi Yu-Chen,
This is an application report for TI Surface mount devices (SMD's): https://www.ti.com/lit/an/snoa550h/snoa550h.pdf It is okay to follow this along with the following standards - for reference: IPC-J-STD-004, IPC-JEDEC J-STD-020, and IPC-JEDEC J-STD-033. These are industry standard specs that TI typically adheres to in the manufacturing process.
As a note - it is also mentioned in the brief - Reflow is okay when you follow the guidelines listed in that document but don't use wave soldering for SMD devices as this is not recommended.
Tyler
