Other Parts Discussed in Thread: TMUXHS221
In the past I used TS3A44159PWR analog switch for switching between 2 LAN ports and its works fine.
In new design I tried to switch USB data (D+ and D-) with the same analog switch but its not works.
I tired to wire USB input and output onboard connectors directly but this works only if I removing the analog switch. Looks that USB data lines overloaded by the switch inputs.
Can I use this chip to switch USB data? If yes, can you recommend the design to switch USB data.
Alex Katsovich
Centrica (Panoramic Power)
