SN74LV4052A: Minimum Ron.
Guru 11345 points
Part Number: SN74LV4052A
Hi team,
Could you tell me the minimum Ron?
BR.
Kengo,
  • Hi Kengo,
    TI typically doesn't provide minimum specifications for Ron parameters because most customers desire lower on-state resistance devices. May I ask why you're inquiring about minimum Ron? What is connected to the switch that requires the minimum value for on-state resistance? Typically lower Ron is not a problem. We only spec typical and maximum as these are the limiting factors for a design for which designs are built around as worst case scenarios.
    Have you seen a competitor device that specifies a minimum on-state resistance?
    Thanks!
    Alex
  • Hi Kengo,
    It's been about a month now. Just wanted to follow up here!
    Alex
