We are using TS5A4594DBVR in our design as per the attachjed image.
Here the purpose of TS5A4594DBVR is to connect or disconnect the 665 OHM resistir between pin 2 and 3 of Instrumentation amplifier to select Gain =1 or 10 for the Instrumentation amplifier(IA).
When we tested this circuit, we observed that the IA was behaving weirdly. The output of IA was not coming as expectected. But when we removed TS5A4594DBVR and 665 OHM, then the IA was functioning as expected.
When we just removed 665 OHM and kept TS5A4594DBVR in the circuit, still the functionality was not correct. Only when we remove TS5A4594DBVR and 665 OHM, the functionality of IA was correct.
So we just checked the resistances of pins of IC TS5A4594DBVR w.r.t Ground. We observed nearly 50K OHM from pin NO to ground. Is this resistance expected? We strongly believe this resistance is causing the treouble in our circuit. Please let us know your inputs on this.
Vijetha HN
