TMUX646: Ibis file
Part Number: TMUX646
Can you point me to the IBIS file for the TMUX646?
  • Hello David,
    We do not have an IBIS model for the TMUX646 currently only a S-parameter model will that work?
    S-parameter models are more commonly used for high speed devices such as the TMUX646 since they provide more accurate results above ~1GHz.
    You can simulate an IBIS model in whatever IBIS software they're using by using the following circuit, which should be a good representation when the switch is on:
    Will this cover your model needs? If you need a more detailed IBIS model or a representational circuit when the switch is off please let us know.
    Nir
