The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
TMUX1511: Could TMU1511 transmit negative voltage
Part Number: TMUX1511
Other Parts Discussed in Thread: TMUX2889, TMUX4827, TS5A22362, LM7705
Hi TIer
1. Could TMUX1511 transmit negative voltage? (When use single ended power supply)
2. When customer use 5V power supply , The channel generates a 7V pulse signal. Will this device be damaged?
Thank you for your supply.
