TMUX1109: TMUX1109 S parameter file
Part Number: TMUX1109
Hi Expert,
As titled, do we have S parameter file for TMUX1109?
Thanks.
  • Hello Bo,
    I wanted to send over the TMUX1109 s parameter file.
    This is a simulated model that should be fine for  testing.
    s1 to s5 represents bandwidth
    s2 to s5 represents off isolation
    s1 to s6 represents crosstalkTMUX1109.snp
    The pin mapping is as follows
    Port1= On channel Source (S1A)
    Port2= Off-channel Source  (S2A)
    Port3= Off-channel Source  (S3A)
    Port4= Off-channel Source  (S4A)
    Port5= On channel Drain (DA)
    Port6= On channel Source (S1B)
    Port7= Off-channel Source  (S2B)
    Port8= Off-channel Source  (S3B)
    Port9= Off-channel Source  (S4B)
    Port10= On channel Drain (DB)
    Please let me know if there are any issues with this model as I am happy to help!
    Kameron
  • Hi Kameron,
    Thank you.
    However, TMUX1109.snp This file cannot be applied to the software at this time
    It looks like 10 ports. Is there a .s10p file?
  • Hello Bo,
    Can you tell me what program/software you are trying to view this file on?
    Kameron
  • Hi Kameron,
    We used Ansys Designer to simulate it. Thanks.
  • Hello Bo,
    Thanks for the extra info.
    So the the snp file I sent you is a s10p file.
    Essentially we could rename that file as s10p file if we wanted to.
    That will not changing any actual characteristics of the model.
    The bigger thing we can try to figure out is why the software you are using is not working.
    I found this online post that explains a problem similar to yours.
    We can keep looking into this together, however I am not familiar with Ansys Designer.
    I suggest you reach out to the Ansys  support team and see if the might know what is going on with the software.
    Please let me know if I can be of any further assistance
    Kameron
