Other Parts Discussed in Thread: TPS65132, , TMUX6236, TMUX7436F
Hi team,
Can MUX4052 support differential signals?
use TPS65132 provide +-6V and signal speed is 5MHz and +-5V
block as below. pls help to check. thanks
Hello Jimmy,
The TMUX4052 can support differential signals up to +-12V and has a typical bandwidth of 600MHz.
It will fit in your application.
Nir
Hi team,
If the input signal is +- 5V~
Does the MUX power input have to have positive and negative voltages?
As shown in the recommended operating conditions, you must not try to switch signals voltages that go beyond the power rails.
Hi team,
I didn't clearly describe my question.
I mean, does the VCC of the MUX have to be positive and negative voltages? if an input signal is bipolar. thanks
If the signals to be switched have positive and negative voltages, then VDD and VSS must be positive and negative.
