TS5A3167 Qc
Other Parts Discussed in Thread: TS5A4594, TS5A3167
Hello
I want to use this part in a sample and hold circuit with VCC=3.3V.
In the datasheet table for 3.3V supply Qc is typical 6pC, but  Figure 5. Charge Injection (QC) vs VCOM shows from -0.6 to +0.8 pC.
What is the correct figure typical and max?
  • Eric,
    Thank you for bringing this to our attention.  I see that the datasheet is a little misleading.  This is most likely due to the electrical table value was taken over temperature and the graph on figure 5 maybe just at room temperature.  I will see if we can make this more clear.
    Thank you,
    Adam
  • Ok, the table does state that the number is at 25 degrees.
    I found that the TS5A4594 has much lower off leakage currents and lower Qc, so its a better part in this application.
    Maybe you could ask about the same difference in the table and graph in figure 5 for that part?
    Does the charge injection happen on both COM and NO/NC pin when the switch is opened?
    If it is only on COM i could connect the sample capacitor to the NO/NC pin instead.
    Thank you,
    Eric
  • Hi, Eric,
    The charge injection would happen on both COM and NO/NC pins. It's measured by looking at the voltage difference on the load (CL) when the switch toggles. As this is a bi-directional switch, you can put your load on either the COM side or the NC/NO side. The result should be very similar.
    I agree with you the figure 5 looks pretty misleading. However, the typ charge injection spec of 6pc should be pretty accurate considering the lower Ron (0.9ohm) of the TS5A3167. The TS5A4594 has a high Ron, hence smaller parasitic caps and lower charge injection. As a rule of thumb, higher Ron==> lower charge injection; lower Ron ==> higher charge injection.
    We will try to figure out the root cause of figure 5. Thanks for bringing it to our attention.
    David
