Regarding TS2PCIE412, do you have any roadmap which has less or equal to Ron = 4 ohm?
Hideyuki Takisawa
Hideyuki Takisawa
Hideyuki-san,
We currently do not have a project on the roadmap to replace the TS2PCIE412. Maybe we have something better in our portfolio we can use as a solution.
What are you planning on using the TS3PCIE412 switch for?
What type of signal are you switching?
What is the bandwidth and voltage range of the signal?
Do you need a 1:2, 1:3, 1:4 switch?
How many signal paths do you need to switch.
How did you calculate 4 ohm on state resistance needed for your solution?
I used the ti.com signal switch selection tool and found that we have several switches with >6 signal paths that have <4 ohm on-state resistance. What do you think about the TS3V712E or TS3L301 switch solution?
Thank you,
Adam
Thank you, Adam-san.
Bandwidth > 400MHz voltage range 1.8V
1:2 mux
2 or 4 signal paths
Hideyuki Takisawa
Hideyuki-san,
Thank you for more details on your signal requirements.
I used the TI.com switch selection tool and filtered swtiches > 400MHz, 1:2, 2 or 4 channels, Ron< 4 ohms. The search returned 7 parts and I would recommend looking at the TS3USB221 or TS3V340.
Let me know if these will work for your application.
Thank you,
Adam
