TS3V713EL: 2 Ch. RGB input, 1 Ch. RGB Output and 3 Ch. RGB input, 1 Ch. RGB Output Suggestion
Part Number: TS3V713EL
Other Parts Discussed in Thread: TS3V712E
Dear Sir,
Do we have 2 ch. RGB input, 1 ch.RGB output solution suggest?
Also need 3 ch. RGB input, 1 ch.RGB output solution suggest.
Thanks, Ian.
  • Hello Ian,
    Unfortunately the part you mention in the post title, TS3V713EL, is a unidirectional part due to the internal unidirectional levelshifters, therefore only capable of 1 input, 2 output.
    However, we do offer a sister part, the TS3V712E which has the same capabilities in term of performance, but no internal levelshifters. This part can be used in a bidirectional manner, so you could use it in the 2 input, 1 output configuration you mentioned.
    We unfortunately do not have any 3 input, 1 output RGB solution at this current time.
    Thank you,
    Louie
  • Dear Louie,
    Does it support 720p resolution? ?
    Thanks, Ian.
  • Hello Ian,
    That answer can be determined by understanding what the optimal bit rate your customer will be using for the 720p resolution.
    As long as that bit rate with within spec of the BW and other recommended operating conditions of the switch, then yes, we support 720p resolution with said part.
    For more information please refer to this snippet of the datasheet in terms of signal limitations:
    and this link that I found on google about the necessary speeds for 720p resolution:
    Thank you,
    Louie
