Other Parts Discussed in Thread: TS5A12301E
Hello. I am considering using the TS12A12511, however, section 10 of the datasheet is giving me pause. That section indicates a requirement for sequencing VCC followed by NC, NO, and COM. In my application, VCC and NC will be tied together, so when VCC comes up, NC will come up at the same rate. COM will come up at the same rate as well since IN will be low when VCC ramps up. NO will be low and not come up for quite some time after. Is the sequencing absolutely necessary or will the device function properly give my application description? Thank you.
