TMUX1219: Open SEL pin on TMUX1219
Part Number: TMUX1219
Hi Team,
If I keep the SEL pin open, will that force a logic low output on my design? Are there any internal pulls or parasitic that could drive it in a different state?
  • Hi Cecilia,
    I have attached a snapshot from the datasheet which highlights what to do with unused selected lines.
    The TMUX1219 does does not have a pull-down resistor so you do not need to have an external resistor for the logic pins. However, if you never plan to toggle the device you could connect the SEL/EN pins to GND. This would ensure that the device doesn't toggle unless there is a shift in your GND voltage.
    Saminah
