I would like you to confirm whether there is any power sequence requirement in following usecase.
* User will use dual voltage (Positive and negative)
Is there any inhibition sequence between VDD and VSS ?
Thanks for your question. For power sequencing in devices without powered-off protection (such as MUX509), it is important to ensure that the power supplies VDD and VSS power up before voltage is present at the I/O pins.
There should not be concern about sequencing between VDD or VSS, as long as both are powered before the signal.
Kate
Thank you for your reply.
I would like you to ask about other MUX50X(X = 6, 7, 8) series
Do other MUX50X also NOT have powered-off protection ?
The MUX50x family does not have the powered-off protection feature.
What is your application and use case? What are the supply voltages (VDD, VSS) and I/O signal voltages needed?
Are you looking for a device with the powered-off protection feature? You can use the product search tool to filter devices by supply voltage, features (such as powered-off protection), and parameters.
More information about simplifying power sequencing with powered-off protection (and how to identify a device with this feature) in this TI Precision Labs training video.
Let me know if you need a suggestion for a device with powered-off protection based on your application.
Kate
Sorry for confusing you.
Customer just use several kind of MUX50X series. So I asked not only MUX509 but also MUX50X.(Since I can only choose one device on "part number" when I post E2E, I asked specific part number(MUX509).)
Your answer was enough for me, so I will close this thread.
BR,
