When simulating TMUX1119. People advice add big resistor to ground. Simulation works with resistors, but result is not wright. How you can add two TMUX1119 following each other.
Hi Jouko,
Could you please elaborate on what you mean by the result isn't correct?
Also where are you adding the resistor to ground at, and what value are you using to simulate?
You should be able to put two models in series to simulate the two devices.
If you could provide a bit more detail in the errors you are seeing that would be great so I could start digging into this problem for you.
Parker Dodson
