SN74CBTLV3125: Hot Swap Application
Part Number: SN74CBTLV3125
Hello Team,
Can the SN74CBTLV3125PWR be used in a Hot Swap Application?
Parker Dodson
  • Hi Parker,
    The SN74CBTLV3125PWR can support hot swap applications (up to its abs max I/O voltage) due to its powered off protection feature. This feature allows the device to provide switch input/output isolation while the device is not powered (note that there can be a maximum of 10uA that may leak to the output in worst case conditions).
    However, if you are trying to protect against a large in-rush current during a hot swap event, then this device will most likely be unable to be used as it can only sustain a maximum of 128mA.
    Thanks!
    Bryan
