I am checking a possibility to use SN74CBT3253C in my design as a multiplexer (4 inputs to 1 output), I would like to know about "break before make" function of the device ("break before make time" - the time delay between shutting off one channel and turning on any other channel in the same quad following the change in S0, S1 logic state without changing OE). The parameter is critical for avoiding shorting of two input signals in multiplexer configuration.
Can you please help me with the information about "break before make time".
Does changing of S0 S1 signals can be made without inserting the device in to the high-Z state using OE pin (p.s. inserting the device to high Z can remove the need in "break before make" delay).
Thank you.
Alex.
