CD74HCT4051: S0~S2 and EN ciriteria? at power up
Part Number: CD74HCT4051
Hello
My customer is using CD74HCT4051 for their new design FY2018.
However, there are problem ( oscillation at COM output  ) for their ES borad in case by case.(cause unknown),
but customer is concerned about their power up sequence  S0~S2, Enable  and Vcc,Vee.
I had attached the schematic and also their problem as ppt file.
Q1  Criteria
Do you have criteria ( timing ) about relationship
between  control input S0~S2 , /Enable  and  Vcc, VEE in case  Power Up( and Down )?
We can not find the criteria those in data sheet.
Q2  Need help as Your opinion
In customer’s desig n, Enable  ( and S0~S2) start up before VEE goes t- -4.5V.
Do you think this is problem?
Q3  Need help as Your opinion
In customer’s set, VEE goes +1V at a moment.( cause unknown)
With my Best Regards
CD74HCT4051_power_up.pptx
  • Hi Kanji,
    We are currently out of office on the 4th of July holiday. We will be back on the 5th and can help address your question.
  • Hi Kanji,
    1) There is no time sequencing criteria for this part. However, it is always good practice to have your supply pins ramp before your enable pin.
    2) This answer is related to the first. Again, the sequencing should not be an issue but you can rule it out by have an external source control your enable and debugging in that manner.
    3) VEE temporarily goes to +1V. this is outside the Abs Max spec of +0.5V . I would not recommend operating in this manner. However, this would not be my first assumption of why the oscillation occurred.
    Common oscillation problems can occur from unstable switching regulators or op amps with insufficient amount of phase margin. One way to rule out the the CD74HCT4051 is to remove the device , blue wire your signal path, and retest.
  • Dear Dakotah-san
    Thank youf your advise precisely.
    Thank you again
