SN74CBTLV1G125: SN74CBTLV1G125DCKR / Information about emboss pocket is incorrect
Part Number: SN74CBTLV1G125
I believe that the length of emboss pocket means maximum, not typical. However the actual size is longer than it, so we guess that the information in datasheet has typo or old. Please refer attached photo that was taken at our logistics.
Satoshi / Japan Disty
  • Satoshi-san,
    Thank you for showing the details of your question.  I will confirm with our manufacturing team the correct dimensions.  Please expect a response from the manufacturing team next week.
    Thank you,
    Adam
  • Hi Adam,
    Thank you for your support. I'm waiting for the feedback from your manufacturing team next week.
    Satoshi
  • Satoshi-san,
    The dimensions in the table are not maximum values but are typical (nominal values).
    Please be aware that pocket dimension measurements are subjective and depend on where in the pocket the measurements are taken as the sides of the pockets are not vertical and actually have a draft angle that can vary up to 10 degrees for certain carrier tapes. So, where the measurements are being taken by the will affect the results
    Also, TI and its sub contractors all comply with to EIA-481 standard pocket tolerance requirements which are measured and compared by quality personnel.
    Thank you,
    Adam
