Other Parts Discussed in Thread: SN74CB3Q3257, TS3A27518E
Hi all. It is so nice to find you all here. I used this device to control the SIM_CLK signal (rise time is 10 ns,f=4.9MHz). When the signal pass the TS3A44159, the waveform will change from square to triangular wave. So I use an 0 R resistor to connect the input and output of MUX together, the signal will be normal. The on capacitance may be the reason. What other reason may cause this problem? I have another question is that how to calculate the max frequency of this device that can normally operate? Thank you!
