Part Number: TS5MP645
Other Parts Discussed in Thread: TS5MP646
Can I use this "TS5MP645" for 10channel analog signal bus switch/mux,
The signal may have frequency about 30Hz to 120Hz.
Is there any limiations in there??
Please guide me!!
Vignesh,
Yes, the TS5MP645 and TS5MP646 may be used for single ended signaling. The limitations of the device are stated in the recommended operating conditions in the datasheet.
What type of signals are you trying to switch/ what are you connecting to the device. Do you know what voltage level and current will be passing through the switch?
Thank you,
Adam
Adam,
The signal is pwm trigger signal for camera( frequency range will be around 30Hz to 120Hz). The voltage level will be 1.8V and current through this will be around some few milli amps.
For the above spec. can i use the TS5MP645.
Awaiting for your reply...
Vignesh.
Vignesh,
The TS5MP645 and TS5MP646 will support 1.8V PWM signals 30-120 Hz with <35mA.
Thank you,
Adam
