Other Parts Discussed in Thread: TMUX1072, TS5A23159
Hi Sir,
Could you please help to confirm the TS5A23157 NC pin will be Hi-Z if when VCC off?
Thank you
Hi Anne,
No the TS5A23157 does not support Hi-Z on signal path pins when VCC is off. This feature is called powered-off protections (Ioff) and is specified when VCC = 0V.
You can sort by this feature in the TI selection tool. We have 6 devices that are 2:1 (SPDT), 2-channel switches with this feature.
What do you think about the TMUX1072 for your application? Or TS5A23159?
Here is an image from the TMUX1072 datasheet showing this feature:
How are you using the switch in your system? This will help recommend the best device.
