Part Number: TX810EVM
Hi!
I see in Figure 3 of the manual a Rin resistor of 75Ohm.
Can anyone explain why this resistor there is required? If I attach a transducer there, the transmitter sees the transducer in parallel to the 75Ohm, so we'll loose some power into the resistor. Again on receive the transducer works with this resistor as the dominant load.
I couldn't see any recommendation of such a resistor in the datasheet of the TX810, there the transducer only is (through a DC block capacitor) connected with the TX810.
I would highly appreciate feedback here. Thanks!
