Other Parts Discussed in Thread: TS5A3159A
When the power supply (VCC) of the switch is off, will the status of the output terminals (B1, B2) be Hi-Z?
Thanks for your question.
Are you looking for a switch that will be high-Z when the switch is powered-off? This is a feature called powered-off protection. SN74LVC1G3157 does not have powered-off protection, and as Clemens mentioned, is at risk of back-powering if a voltage is applied on I/O pins when powered-off.
What is your use case for needing a high-Z state switch when powered-off? Take a look at TS5A3159A which has powered-off protection and is pin-compatible with SN74LVC1G3157 and let me know what you think.
In addition, let me share with you some resources that provide more detail on powered-off protection and how to identify and search for a switch with powered-off protection.
Kate
Clemens,
Thank you for your prompt response.
Currently, voltage was applied to the I / O pins when the power was turned off, so
I would like to review the circuit because there are concerns that I received comments.
thanks a lot for your help,
Toshiyuki Yoshizawa
Kate,
I wanted to take measures against one-sided power supply by wrapping around to the connected external sensor.
I would like to consider using the "TS5A3159A" that you have proposed.
Toshiyuki Yoshizawa
