Hi Team,
I would like to get your input with the customer design using MPC506 to read a number of 15 signals (analog and digital).
The customer would like to confirm if he can supply it with +5 volts and leaving the negative voltage supply pin floating?
Is it fine to pass different signal types (analog & digital) without affecting the values of these signals?
Can he connect the enable pin and Vref pin to the same power supply?
will the signals affect each other while the Mux turned off?
Here's the image for the proposed design:
Please let me know any questions you have with the customer.
Jonathan
