Hi Sir,
may i know how many MT/sec for TS3DDR4000?
Hi Tommy,
We don't directly spec MT/s on this part but it can be found using the bandwidth:
Assuming two bits transferred per cycle (DDR)
Single Ended Bandwidth (Over Rec. VDD range and terminated with 50 Ohm Load) = 5.6GHz (typ) ~ 10.2GT/s (typ)
Differential Bandwidth (Over Rec. VDD range and terminated with 100 Ohm load between differential outputs) = 6GHz (typ) ~ 12GT/s (typ)
Load Capacitance, including parasitics, can degrade the bandwidth, but unless a large output capacitance is present this shouldn't affect the bandwidth much.
If you have any other questions please let me know!
Parker Dodson
