Other Parts Discussed in Thread: TMUX1136, TMUX1119
Do you have 3.3-V, "2:1", 2-channel analog multiplexer which supports Ioff function? Thanks.
Hi Bryan,
Thank you for the prompt reply.
Sorry, this is my first time to use multiplexers with Ioff function, I'm not quite familiar with it.
The Ioff function is the same as the Low-Leakage-Current protection, am I right? could you explain it?
We have two system board, when one SB is powered-on, critical signal may be pulled down on current circuit during inserting or pull other SB, so I need improve this problem.
Thanks.
Hi Duke,
The IOFF parameter specifies how much current will leak through the switch to the output when the switch is in the Hi-Z/OFF state. So even if you do not have that specific channel selected on the switch, you will still see some leakage through the switch, but it is bounded by this IOFF parameter.
Do you have a partial schematic you could share? The TMUX1136 has extremely low IOFF leakage in the single digit pA range at room temperature so that device might best fit your application if you are concerned about any excess leakage affecting your downstream circuity.
Thanks!
Bryan
Hi Bryan,
Thank you so much for your detailed explanation.
Below is our design concept, it seems to me that I can choose TMUX1119(2:1, 1-Channel Precision Analog Switch).
Thanks.
Hi Duke,
the TMUX1119 is perfectly acceptable to use for a 2:1 mux application and has great IOFF performance. This should work fine!
Thanks!
Bryan
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
