Hi team,
Can the TS3A227E detect the both 3.5mm audio accessory as below picture?
thanks.
Prescott
Hi team,
thanks.
Prescott
Prescott,
Please confirm that you are showing a stereo 3 pole accessory (top) and mono 2 pole accessory (bottom).
When the TS3A227E runs its detection sequence it compares the impedance between the tip and Ring 2 and the Tip and Sleeve of the audio accessory. Since both the 2 pole and 3 pole accessory have the Ring 2 and sleeve grounded the impedance from tip to ring 2 and tip to sleeve will be the same. When the impedance are equal the TS3A227E will automatically detect and configure it self to support a 3 pole accessory for both audio accessories.
Yes the TS3A227E will support both accessories but its automatic detection sequence cannot determine the difference between the 2-pole and 3-pole accessory.
You can see these post for more information on how the audio jacks do their accessory detection.
Thank you,
Adam
