Other Parts Discussed in Thread: TS5A23157, TS3V340, TS3USBA225
Hi. Expert .
My customer to request IBIS model for TS3L501E.
Can I get a IBIS model for TS3L501E?
Regards.
Takakura
Hi. Expert .
Regards.
Takakura
Koki-san,
What are you trying to accomplish with the Input/output Buffer Information Specification (IBIS) model? The TS3L501E signal paths are pass FETs with out any buffering so buffer information model is not applicable to the signal path. The IBIS model would only be valid for the control logic inputs of the TS3L501E which are buffered.
You can also make a simple model of the signal path using the parasitic on-state resistance Ron and onstate capacitance Con. More information on our different types of FET switches can be found in this app note "selecting the correct signal switch"
Thank you,
Adam
Hi Adam-san.
Thank you for your comment.
My customer wanted to the TL3L501E signal information checked.
I confuse because your comment.
I could get other switch's IBIS model information from TI HP.
For example TS3V340,TS3USBA225 and TS5A23157.
TS3V340 http://www.tij.co.jp/product/jp/TS3V340/toolssoftware
TS3USBA225 http://www.tij.co.jp/product/jp/TS3USBA225/toolssoftware
TS5A23157 http://www.tij.co.jp/product/jp/TS5A23157/toolssoftware
These devices are the same FET switch as TL3L501E.
Why only TL3L501E doesn't have IBIS model?
Best, Regard.
Takakura
Adam-san
Thank you for your quick response.
I understood the description.
If my customer needs HSPICE models,whom should I request ?
Best ,Regard.
Takakura
Takakura-san,
I believe you may request a model in the simulation models e2e forum. Let me know if you are able to request a model from that team or I will help you find another route.
Thank you,
Adam
