TS3A227E: Vdd rise and fall times
Guru 20090 points
Part Number: TS3A227E
Could you please let me know the minimum and maximum Vdd rise and fall times?
In the datasheet P.47 Power supply recommendations section , there is the description that " To ensure a POR trip during a power-down and power-on event the power supply should follow the minimum and maximum V DD rise and fall times specified in the electrical specifications section."
However, I couldn't found the minimum and maximum Vdd rise and fall times from the datasheet.
Ryuji
  • Ryuji,
    Thank you for pointing out that we forgot to include the POR spec in the table referenced in the power supply recommendation.  I have put in a request to our design team to verify the spec so we can add it to the datasheet.
    Thank you,
    Adam
  • Adam san,
    Thank you for your reply. Please let me know the PoR spec when the team verified the spec.
    Ryuji
  • Ryuji,
    You have caught an error in our TS3A227E datasheet. We did not intend to mention a POR requirement in the datasheet and are going to remove that statement in the power supply recommendations section.
    Our design team says if your ramp rate is > 4.5 V/ms you will not run into POR issues due to power supply ramp rates.
    I'm sorry for the error.
    Thank you,
    Adam
