SN74LV4051A-Q1: ESD MM(Machine Model) Level for SN74LV4051-Q1?
Part Number: SN74LV4051A-Q1
Now customer ask for ESD MM(Machine Model) Level for SN74LV4051-Q1 at Automotive battery module.  But I can’t look for MM level in datasheet(below).  Can you provide to me for ESD MM(Machine Model) Level for SN74LV4051-Q1?
Please send me for your response.
Thanks!
  • Hi Adam,
    TI now has a new datasheet standard where information has been added to some sections (Thermal Information) and some information has been removed from other sections.
    Machine model ESD ratings are not required by the majority of customers anymore therefore new products are not tested for this ESD rating. However, HBM and MM have similar failure mechanisms due to the similarity in test configuration. The MM is also not as reliable for evaluting ESD performance as the HBM and CDM.
    I have linked an app note on ESD parameters to explain a bit more. As well as webpage explaining the similarity in test configurations and results.
    I have also included two other E2E posts with similar explanations on the MM ESD questions:
