Hi
In my application I won't be using FLT(FLT 12 - O Fault indicator output pin (Active low) - open drain) pin. Do I need to connect it to GND or Can I keep it as floating.
Hari
Hari,
The TMUX1072 FLT indicator pin is an open drain output so you may leave it floating or ground it if you are not using this feature.
What type of circuit are you using this device that you do not need FLT detection?
Thank you,
Adam
