Hi All,
I use tiobj2bin.bat to convert .out to .bin as the steps below, but it failed.
1. I copy the essential 3 exe(ofd6x,hen6x and mk6x) under C:\Texas Instruments\ccsv5\tools\compiler\c6000\bin to cg_xml\utils directory.(Not necessary, just for convenience)
2. Type the command in console as:
C:\Texas Instruments\cg_xml\ofd>tiobj2bin.bat myprj.out myprj.bin ..\utils\ofd6x.exe ..\utils\hex6x.exe ..\utils\mk6x.exe
But in the process, the console report the error:
>> File "c:\docume~1\admini~1\locals~1\temp\ofd_11111_6748_22864.xml" not an archive
error: -image requires ROMS directive
I check the tiobj2bin.bat and find ofd_xx_xx_xx.xml should be an intermediate file which is generated from .out by ofd6x.exe and is used to generate hex file by hex6x.exe. I don't know why the error occurs. And I try to change the path and name of this file, but the result is the same.
The version of my CCS is 5.0.3.00023 and the cg_xml is 2.30.
Allen
