Dear all:
My CCS crack right after I try to build my project. And my computer is auto-reseted at the same time.
When I open my project again after the reset, I found one of my file crack! with all the data inside is 0(I check it by notepad++ with HEX view), but the file size is the same as original.4621.slaveTask.c
Then I try to pelace the cracked file by the backup one. After I build it again, I got the following error message
after select "OK", i can still build my project and run.
my question is, how can the crack of CCS and my file happened? and is there and way to fix the cracked file?
I've met this twice in this week.
CCS 5.4.0.00091
compiler TI v7.4.6
OS: windows7 64bit
Thank you very much!
