Archiver .a and .lib difference
I notice that there are two types of library files: .a and .lib.
Both are described in ARM compiler/assembler as libraries.
As libraries are eventually linked by linker, I do not see obvious difference between the two such as between dynamic linked DLL and static LIB. What is the key difference between .a and .lib?
Cheers,
  • This description applies only to the libraries found in the /lib directory of the TI ARM compiler installation.  That said, the conventions established there are commonly used elsewhere.
    A .lib file is a library of object files.  Such a library is created with the command armar.  That command is described in the chapter titled Archiver Description in the ARM assembly language tools manual.  A .a file is an index library.  It is created with the command armlibinfo.  This command is described in the sub-chapter titled Library Information Archiver Description.
    Thanks and regards,
    -George
