I got an installation problem with the CCS 6 offline installer which I downloaded from the link below:
software-dl.ti.com/.../self_cert_export.html;ref_url=software-dl.ti.com/.../CCS_6_1_0
Actually I previously tried the web installer but it doesn't work so I turned to this offline installer but it's still not working.
In fact, I got the following error message during the installation:
06/12/2015 07:44:19(GMT) - downloadIfRequired - deleted C:/Documents and Settings/aeeyhtsoi/Local Settings/Temp/ccs_4f32181c-5398-4db3-503e-b98b8e7c3d4e/jre_root_1.7.0.60
06/12/2015 07:44:19(GMT) - downloadIfRequired - File C:/Documents and Settings/aeeyhtsoi/Local Settings/Temp/ccs_4f32181c-5398-4db3-503e-b98b8e7c3d4e/jre_root_1.7.0.60 already exists. Not attempting to download
06/12/2015 07:44:19(GMT) - extract - file C:/Documents and Settings/aeeyhtsoi/Local Settings/Temp/ccs_4f32181c-5398-4db3-503e-b98b8e7c3d4e/jre_root_1.7.0.60 doesn't exist
06/12/2015 07:44:29(GMT) - extract - file C:/Documents and Settings/aeeyhtsoi/Local Settings/Temp/ccs_4f32181c-5398-4db3-503e-b98b8e7c3d4e/jre_root_1.7.0.60 doesn't exist
06/12/2015 07:44:39(GMT) - checkStatus - CCS_ERROR: Installer failed to install jre correctly. The 2 most common reasons for failure are:
1. Anti-virus on your computer could have impeded the executable.
2. Download is corrupted.
Please submit these logs to TI for analysis using the next dialog.
You may also visit the TI Online CCS support form for additional help.
06/12/2015 07:43:22(GMT) - checkAV - CCS_INFO: av message
06/12/2015 07:43:24(GMT) - checkAVAgain - CCS_INFO: av message
06/12/2015 07:43:28(GMT) - checkProgramFiles - CCS_INFO: checking c:\program files
06/12/2015 07:43:28(GMT) - checkProgramFiles - CCS_INFO: ProgramFilesDir (x86) does not exist
06/12/2015 07:43:28(GMT) - checkProgramFiles - CCS_INFO: ProgramW6432Dir does not exist
06/12/2015 07:43:28(GMT) - Util::httpCopy - http::config now: -accept */* -proxyfilter http::ProxyRequired -proxyhost {} -proxyport {} -urlencoding utf-8 -useragent {Tcl http client package 2.5.2}
06/12/2015 07:43:28(GMT) - Util::httpCopy - Downloading C:/Documents and Settings/aeeyhtsoi/Local Settings/Temp/ccs_4f32181c-5398-4db3-503e-b98b8e7c3d4e/apps_6.1.0.json from http://software-dl.ti.com/ccs/non-esd/ccs_appcenter/apps_6.1.0.json
06/12/2015 07:43:49(GMT) - Util::httpCopy - Could not get file http://software-dl.ti.com/ccs/non-esd/ccs_appcenter/apps_6.1.0.json:couldn't open socket: connection timed out
06/12/2015 07:43:59(GMT) - writeDebugFile -
Install Information:
06/12/2015 07:43:59(GMT) - writeDebugFile - Install Version: 6.1.0.00104
06/12/2015 07:43:59(GMT) - writeDebugFile - Install Source : D:/aeekwyan/Acc Sensing/CC3200/CCS/offline installer 2/CCS6.1.0.00104_win32
06/12/2015 07:43:59(GMT) - writeDebugFile - Install Temp : C:/Documents and Settings/aeeyhtsoi/Local Settings/Temp/ccs_4f32181c-5398-4db3-503e-b98b8e7c3d4e
06/12/2015 07:43:59(GMT) - writeDebugFile - Install Type : Offline
06/12/2015 07:43:59(GMT) - writeDebugFile - OS : Windows NT
06/12/2015 07:43:59(GMT) - writeDebugFile - OS Version : 5.1
06/12/2015 07:43:59(GMT) - writeDebugFile - OS Platform : windows
06/12/2015 07:43:59(GMT) - writeDebugFile - : 32-bit
06/12/2015 07:43:59(GMT) - writeDebugFile - User ID : aeeyhtsoi
06/12/2015 07:43:59(GMT) - writeDebugFile - Timezone : China Standard Time
06/12/2015 07:43:59(GMT) - writeDebugFile - IPAddress : 10.106.102.69
06/12/2015 07:43:59(GMT) - writeDebugFile - Update/Rerun : 0
06/12/2015 07:43:59(GMT) - writeDebugFile - Command line : installersrc {D:/aeekwyan/Acc Sensing/CC3200/CCS/offline installer 2/CCS6.1.0.00104_win32} installertmp {C:/Documents and Settings/aeeyhtsoi/Local Settings/Temp/ccs_4f32181c-5398-4db3-503e-b98b8e7c3d4e} buildid 6.1.0.00104 installer {D:/aeekwyan/Acc Sensing/CC3200/CCS/offline installer 2/CCS6.1.0.00104_win32/ccs_setup_6.1.0.00104.exe} bitness 32-bit
Product families selected:
06/12/2015 07:43:59(GMT) - writeDebugFile - PF_WIRELESS
Components to be installed:
06/12/2015 07:43:59(GMT) - writeDebugFile - DEV_SUPPORT_CC32XX
06/12/2015 07:43:59(GMT) - writeDebugFile - ARM_CGT_HELP
06/12/2015 07:43:59(GMT) - writeDebugFile - CGT_DEFAULTLIBS_TMS470
06/12/2015 07:43:59(GMT) - writeDebugFile - DMED
06/12/2015 07:43:59(GMT) - writeDebugFile - EMU_TI
06/12/2015 07:43:59(GMT) - writeDebugFile - JRE
06/12/2015 07:43:59(GMT) - writeDebugFile - P2APP
06/12/2015 07:43:59(GMT) - writeDebugFile - ECLIPSE
06/12/2015 07:43:59(GMT) - writeDebugFile - ECLIPSECORE
06/12/2015 07:43:59(GMT) - writeDebugFile - P2TOOLS
06/12/2015 07:43:59(GMT) - writeDebugFile - GMF
06/12/2015 07:43:59(GMT) - writeDebugFile - IDE_MAIN
06/12/2015 07:43:59(GMT) - writeDebugFile - IDE_WORKFLOW
06/12/2015 07:43:59(GMT) - writeDebugFile - DVT_COMMON
06/12/2015 07:43:59(GMT) - writeDebugFile - DVT_UIA
06/12/2015 07:43:59(GMT) - writeDebugFile - DVT_VIA_CCS
06/12/2015 07:43:59(GMT) - writeDebugFile - INSTALLER
06/12/2015 07:43:59(GMT) - writeDebugFile - IDE_CHROME
06/12/2015 07:43:59(GMT) - writeDebugFile - IDE_TOOLS_COMMON
06/12/2015 07:43:59(GMT) - writeDebugFile - IDE_GC
06/12/2015 07:43:59(GMT) - writeDebugFile - TARGET_CONTENT_CORE
06/12/2015 07:43:59(GMT) - writeDebugFile - IDE_ARM
06/12/2015 07:43:59(GMT) - writeDebugFile - DVT_TRACE
06/12/2015 07:43:59(GMT) - writeDebugFile - DS
06/12/2015 07:43:59(GMT) - writeDebugFile - DS_FLASH
06/12/2015 07:43:59(GMT) - writeDebugFile - MSVC80
06/12/2015 07:43:59(GMT) - writeDebugFile - MSVC2012
06/12/2015 07:43:59(GMT) - writeDebugFile - TIVA_STELLARIS_DRIVERS
Apps to be installed when CCS starts up:
06/12/2015 07:43:59(GMT) - getprefix - installdir for ARM_CGT_HELP: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getprefix - installdir for C2000_CGT_HELP: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getprefix - installdir for C5500_CGT_HELP: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getprefix - installdir for C6000_CGT_HELP: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getinstalluninstallcmds - Did not find matching component in InstallIni CCS_DOC. Using Defaults.
06/12/2015 07:43:59(GMT) - getinstalluninstallcmds - Did not find matching component in InstallIni CCS_LAUNCHER. Using Defaults.
06/12/2015 07:43:59(GMT) - getinstalluninstallcmds - Did not find matching component in InstallIni CCS_UTILS. Using Defaults.
06/12/2015 07:43:59(GMT) - getprefix - installdir for DVT_COMMON: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getprefix - installdir for DVT_ENERGYTRACE: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getprefix - installdir for DVT_TRACE: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getprefix - installdir for DVT_UIA: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getprefix - installdir for DVT_VIA_CCS: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getprefix - installdir for ECLIPSE: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getprefix - installdir for EMU_SD: c:/ti/ccsv6/ccs_base
06/12/2015 07:43:59(GMT) - getprefix - installdir for GMF: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getprefix - installdir for IDE_ARM: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getprefix - installdir for IDE_C2000: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getprefix - installdir for IDE_C5500: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getprefix - installdir for IDE_C6000: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getprefix - installdir for IDE_CHROME: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getprefix - installdir for IDE_GC: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getprefix - installdir for IDE_MAIN: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getprefix - installdir for IDE_MSP430: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getprefix - installdir for IDE_TOOLS_COMMON: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getprefix - installdir for IDE_WORKFLOW: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getprefix - installdir for KEYSTONE1: c:/ti/ccsv6/ccs_base
06/12/2015 07:43:59(GMT) - getprefix - installdir for KEYSTONE2: c:/ti/ccsv6/ccs_base
06/12/2015 07:43:59(GMT) - getprefix - installdir for MSP430_CGT_HELP: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getinstalluninstallcmds - Did not find matching component in InstallIni MSVC_REDIST_2005. Using Defaults.
06/12/2015 07:43:59(GMT) - getprefix - installdir for MSVC_REDIST_2005: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getinstalluninstallcmds - Did not find matching component in InstallIni MSVC_REDIST_2012. Using Defaults.
06/12/2015 07:43:59(GMT) - getprefix - installdir for MSVC_REDIST_2012: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getprefix - installdir for P2APP: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getprefix - installdir for P2TOOLS: c:/ti/ccsv6/
06/12/2015 07:43:59(GMT) - getinstalluninstallcmds - Did not find matching component in InstallIni TARGETDB_DEF_PROPS. Using Defaults.
06/12/2015 07:43:59(GMT) - getprefix - installdir for TARGET_CONTENT_CORE: c:/ti/ccsv6/..
06/12/2015 07:43:59(GMT) - Util::getProperty - No c:/ti/ccsv6/eclipse/ccs.properties file found
06/12/2015 07:43:59(GMT) - ProgressPane::Run - Starting install process in separate thread
06/12/2015 07:43:59(GMT) - ProgressPane::Run - call = RunInstall c:/ti/ccsv6/eclipse/ccs_config.xml 0 0 0 0 c:/ti/ccsv6/install_logs/ccs_setup_6.1.0.00104_install.log ::progressPane0 tid000000F4
06/12/2015 07:43:59(GMT) - ProgressPane::Run - separate threads
06/12/2015 07:43:59(GMT) - ProgressPane::Run - thread = tid00000DB8
06/12/2015 07:43:59(GMT) - RunMain - Started with params pConfigFile=c:/ti/ccsv6/eclipse/ccs_config.xml pProfiling=0 pUpdate=0 logfile=c:/ti/ccsv6/install_logs/ccs_setup_6.1.0.00104_install.log progress=::threadedProgressUpdate0
06/12/2015 07:43:59(GMT) - RunMain - encoding = cp1252
06/12/2015 07:43:59(GMT) - readConfigFile - Start installing components:
06/12/2015 07:43:59(GMT) - readConfigFile - read config file c:/ti/ccsv6/eclipse/ccs_config.xml
06/12/2015 07:43:59(GMT) - readConfigFile - found c:/ti/ccsv6/eclipse/ccs_config.xml
06/12/2015 07:43:59(GMT) - readConfigFile - Parsing Root Elements
06/12/2015 07:43:59(GMT) - readConfigFile - Done Parsing
06/12/2015 07:43:59(GMT) - readConfigFile - CCSDIR=c:/ti/ccsv6
06/12/2015 07:43:59(GMT) - readConfigFile - EclipseDir=c:/ti/ccsv6/eclipse
06/12/2015 07:43:59(GMT) - readConfigFile - InstallDir=c:/ti
06/12/2015 07:43:59(GMT) - readConfigFile - TempDir=C:/Documents and Settings/aeeyhtsoi/Local Settings/Temp/ccs_4f32181c-5398-4db3-503e-b98b8e7c3d4e
06/12/2015 07:43:59(GMT) - readConfigFile - platform=windows
06/12/2015 07:43:59(GMT) - readConfigFile - LocalBaseRepository=D:/aeekwyan/Acc Sensing/CC3200/CCS/offline installer 2/CCS6.1.0.00104_win32/baserepo
06/12/2015 07:43:59(GMT) - readConfigFile - baserepourl=D:/aeekwyan/Acc Sensing/CC3200/CCS/offline installer 2/CCS6.1.0.00104_win32/baserepo
06/12/2015 07:43:59(GMT) - readConfigFile - featureurl=D:/aeekwyan/Acc Sensing/CC3200/CCS/offline installer 2/CCS6.1.0.00104_win32/featurerepo
06/12/2015 07:43:59(GMT) - readConfigFile - LocalRepository_Exists=1
06/12/2015 07:43:59(GMT) - readConfigFile - componentinstaller=false
06/12/2015 07:43:59(GMT) - readConfigFile - eclipseexe=eclipsec.exe
06/12/2015 07:43:59(GMT) - readConfigFile - in install components
06/12/2015 07:43:59(GMT) - readUserProfile - userprofile = C:\Documents and Settings\aeeyhtsoi
06/12/2015 07:43:59(GMT) - downloadIfRequired - deleted C:/Documents and Settings/aeeyhtsoi/Local Settings/Temp/ccs_4f32181c-5398-4db3-503e-b98b8e7c3d4e/jre_root_1.7.0.60
06/12/2015 07:43:59(GMT) - downloadIfRequired - File C:/Documents and Settings/aeeyhtsoi/Local Settings/Temp/ccs_4f32181c-5398-4db3-503e-b98b8e7c3d4e/jre_root_1.7.0.60 already exists. Not attempting to download
06/12/2015 07:43:59(GMT) - extract - file C:/Documents and Settings/aeeyhtsoi/Local Settings/Temp/ccs_4f32181c-5398-4db3-503e-b98b8e7c3d4e/jre_root_1.7.0.60 doesn't exist
06/12/2015 07:44:09(GMT) - extract - file C:/Documents and Settings/aeeyhtsoi/Local Settings/Temp/ccs_4f32181c-5398-4db3-503e-b98b8e7c3d4e/jre_root_1.7.0.60 doesn't exist
The install logs are located in: c:/ti/ccsv6/install_logs.
06/12/2015 07:44:39(GMT) - checkStatus - file does not exist C:/Documents and Settings/aeeyhtsoi/Local Settings/Temp/ccs_4f32181c-5398-4db3-503e-b98b8e7c3d4e/eclipse/ws/.metadata/.log
06/12/2015 07:44:39(GMT) - checkStatus - saving c:/ti/ccsv6/install_logs
06/12/2015 07:44:39(GMT) - checkStatus - CCS_ERROR: Code Composer Studio v6 installation failed.
Hopefully, someone can help me out from that...
Much Thx,
Kelvin
