Regarding searching for text in CCS v6
I am a new user of CCS v6.1 and I am having trouble searching for text in CCS v6.1.0.  CCS v3.3 was very convenient as I was able to easily look for variables, addresses, text in .c or .h files in a project. Can you let me know how to run similar searches in CCS v6.1.0?
I am working on a project file that was imported from V3.3 to v6, I tried using 'File Search' as well as "C/C++Search", the project location has been included in 'Include Options'  the search function works well for text in .c files, but it  do not work well for searching through header files or searching for hex numbers/addresses.
- C/C++ Search for hex number(e.g. 0x10003B) in any file does not work. For example, 0 matches for 0x10003B in .c or .h files.
- C/C++ Search  for variable name used in .h as well as .c file: returns results correctly in both .c file as well as .h files.
- File Search for hex number(e.g. 0x10003B) in any file works partially. It returns correct search results for 0x10003B in .c files only. Does not return search results for hex numbers in .h file.
- File Search for variable name used in .h as well as .c file: returns results of only .c files.
Is there a setting I need to change? Thanks,
Gysler
  • Hello Gysler,
    This short video show how to run similar searches in CCSv6:
    Only the C/C++ search will pick up header files outside the project folder
    C/C++ Search is limited to specific element types. See:
    As mentioned in the video posted above, the File Search will only return results in *.h files if the file is physically inside the project folder
    Same as above.
    Unfortunately this is a known Eclipse CDT limitation. There have been bugs filed against the Eclipse community for this but the current status is that it remains unresolved. Hopefully they fix this in a future release.
    ki
