Hi
I have been working on ADC Read code in CCS. code is given below,
#include "Board.h"
#include <ti/sysbios/knl/Semaphore.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/knl/Clock.h>
#include <ti/sysbios/family/arm/m3/Hwi.h>
#include <ti/sysbios/family/arm/cc26xx/Power.h>
#include <ti/sysbios/BIOS.h>
#include <ti/drivers/PIN/PINCC26XX.h>
#include <ti/drivers/UART.h>
#include <driverlib/aux_adc.h>
#include <driverlib/aux_wuc.h>
#include <inc/hw_aux_evctl.h>
#define TASK_STACK_SIZE 512
#define TASK_PRI 1
char
taskStack[TASK_STACK_SIZE];
Task_Struct taskStruct;
Semaphore_Struct sem;
Semaphore_Handle hSem;
Hwi_Struct hwi;
#define SAMPLECOUNT 8
#define SAMPLETYPE uint16_t
#define SAMPLESIZE sizeof(SAMPLETYPE)
#define ALS_POWER IOID_26
#define ALS_OUTPUT IOID_23
SAMPLETYPE adcSamples[SAMPLECOUNT];
SAMPLETYPE singleSample;
// Analog light sensor pins
const
PIN_Config alsPins[] = {
ALS_POWER | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_PUSHPULL | PIN_DRVSTR_MAX,
ALS_OUTPUT | PIN_INPUT_DIS | PIN_GPIO_OUTPUT_DIS ,
PIN_TERMINATE
PIN_Handle pinHandle;
PIN_State pinState;
UART_Handle uHandle;
void
taskFxn(UArg a0, UArg a1);
void
adcIsr(UArg a0);
int
main(
void
//Initialize pins, turn on GPIO module
PIN_init(BoardGpioInitTable);
//Initialize task
Task_Params params;
Task_Params_init(¶ms);
params.priority = TASK_PRI;
params.stackSize = TASK_STACK_SIZE;
params.stack = taskStack;
Task_construct(&taskStruct, taskFxn, ¶ms, NULL);
// Construct semaphore used for pending in task
Semaphore_Params sParams;
Semaphore_Params_init(&sParams);
sParams.mode = Semaphore_Mode_BINARY;
Semaphore_construct(&sem, 0, &sParams);
hSem = Semaphore_handle(&sem);
BIOS_start();
void
taskFxn(UArg a0, UArg a1) {
Hwi_Params hwiParams;
Hwi_Params_init(&hwiParams);
hwiParams.enableInt =
true
Hwi_construct(&hwi, INT_AUX_ADC, adcIsr, &hwiParams, NULL);
UART_Params uParams;
// Initialize default values
UART_Params_init(&uParams);
// Configure custom data, don't care about read params as not used
// 115.2kBaud, Text, blocking mode
uHandle = UART_open(Board_UART,&uParams);
// Set up pins
pinHandle = PIN_open(&pinState, alsPins);
// Enable clock for ADC digital and analog interface (not currently enabled in driver)
AUXWUCClockEnable(AUX_WUC_MODCLKEN0_SOC_M|AUX_WUC_MODCLKEN0_AUX_ADI4_M);
// Connect AUX IO7 (DIO23) as analog input. Light sensor on SmartRF06EB
AUXADCSelectInput(ADC_COMPB_IN_AUXIO7);
// Set up ADC
AUXADCEnableSync(AUXADC_REF_FIXED, AUXADC_SAMPLE_TIME_2P7_US, AUXADC_TRIGGER_MANUAL);
// Disallow STANDBY mode while using the ADC.
Power_setConstraint(Power_SB_DISALLOW);
uint8_t currentSample = 0;
while
(currentSample < SAMPLECOUNT) {
//Sleep 100ms in IDLE mode
Task_sleep(100 * 1000 / Clock_tickPeriod);
// Trigger ADC sampling
AUXADCGenManualTrigger();
// Wait in IDLE until done
Semaphore_pend(hSem, BIOS_WAIT_FOREVER );
adcSamples[currentSample++] = singleSample;
// Disable ADC
AUXADCDisable();
// Allow STANDBY mode again
Power_releaseConstraint(Power_SB_DISALLOW);
// Restore pins to values in BoardGpioTable
PIN_close(pinHandle);
// Log data through UART
for
(uint8_t i = 0; i<SAMPLECOUNT; i++ ) {
UART_write(uHandle, &adcSamples[i], SAMPLESIZE);
// Goto STANDBY forever
Task_sleep(BIOS_WAIT_FOREVER);
void
adcIsr(UArg a0) {
// Pop sample from FIFO to allow clearing ADC_IRQ event
singleSample = AUXADCReadFifo();
// Clear ADC_IRQ flag. Note: Missing driver for this.
HWREGBITW(AUX_EVCTL_BASE + AUX_EVCTL_O_EVTOMCUFLAGSCLR, AUX_EVCTL_EVTOMCUFLAGSCLR_ADC_IRQ_BITN) = 1;
// Post semaphore to wakeup task
Semaphore_post(hSem);
#10234-D unresolved symbols remain ADCRead C/C++ Proble
The build message shows unresolved symbol as follows
undefined first referenced
symbol in file
ResetISR
error #10234-D: unresolved symbols remain
warning #10062-D: entry-point symbol "ResetISR" undefined
How can I avoid all these errors and create stand alone error free ccs project for Reading ADC value?
