  • Resolved
ARM TI code generation tools: armofd.exe truncates long names
Expert 6270 points
I am running the command: armofd.exe --obj_display=none,sections Dem_Client.o
code generation tools: ti-cgt-arm_5.2.5\bin
But I notice that the sections names are truncated when it reaches a certain length.
Please see the sample output below.
How can I display the full text of the section name without converting the output into XML?
Copied from Command Prompt
arm\bin>armofd.exe --obj_display=none,sections Dem_Client.o
OBJECT FILE:  Dem_Client.o
 Section Information
    id name                      load addr  run addr    size align alloc
     0 (no name)                 0x00000000 0x00000000   0x0     0   N
     1 .text                     0x00000000 0x00000000   0x0     2   Y
     2 .data                     0x00000000 0x00000000   0x8     4   Y
     3 .bss:Dem_TxData           0x00000000 0x00000000 0x120     2   Y
     4 .text:Dem_SetEvStatusF... 0x00000000 0x00000000  0x3c     4   Y
     5 .text:Dem_SaveErrorPre... 0x00000000 0x00000000  0x90     4   Y
     6 .text:Dem_ReportErrorS... 0x00000000 0x00000000  0x48     4   Y
     7 .text:Dem_GetEventIdValid 0x00000000 0x00000000  0x38     2   Y
     8 .text:Dem_SetEventStatus  0x00000000 0x00000000  0x30     4   Y
     9 .text:Dem_ResetSlaveEv... 0x00000000 0x00000000   0xc     4   Y
    10 .text:Dem_InitHwErrors    0x00000000 0x00000000  0x10     4   Y
    11 .text:Dem_InitPreExtData  0x00000000 0x00000000  0x28     4   Y
    12 .text:Dem_PreInit         0x00000000 0x00000000  0x58     4   Y
    13 .text:Dem_TaskSlaveEve... 0x00000000 0x00000000  0x40     4   Y
    14 .text:Dem_MainFunction    0x00000000 0x00000000  0x1c     4   Y
    15 .text:Dem_Init            0x00000000 0x00000000  0x1c     4   Y
    16 .ARM.attributes           0x00000000 0x00000000  0x58     0   N
    17 .symtab                   0x00000000 0x00000000 0x780     0   N
    18 .rel.text:Dem_SetEvSta... 0x00000000 0x00000000  0x18     0   N
    19 .rel.text:Dem_SaveErro... 0x00000000 0x00000000  0x30     0   N
    20 .rel.text:Dem_ReportEr... 0x00000000 0x00000000  0x28     0   N
    21 .rel.text:Dem_GetEvent... 0x00000000 0x00000000   0x8     0   N
    22 .rel.text:Dem_SetEvent... 0x00000000 0x00000000  0x20     0   N
    23 .rel.text:Dem_InitHwEr... 0x00000000 0x00000000  0x10     0   N
    24 .rel.text:Dem_InitPreE... 0x00000000 0x00000000  0x10     0   N
    25 .rel.text:Dem_PreInit     0x00000000 0x00000000  0x58     0   N
    26 .rel.text:Dem_TaskSlav... 0x00000000 0x00000000  0x38     0   N
    27 .rel.text:Dem_MainFunc... 0x00000000 0x00000000  0x18     0   N
    28 .rel.text:Dem_ResetSla... 0x00000000 0x00000000   0x8     0   N
    29 .rel.text:Dem_Init        0x00000000 0x00000000  0x10     0   N
    30 .TI.symbol.alias          0x00000000 0x00000000   0x9     0   N
    31 .TI.section.flags         0x00000000 0x00000000  0x1a     0   N
    32 .strtab                   0x00000000 0x00000000 0x665     0   N
    33 .shstrtab                 0x00000000 0x00000000 0x310     0   N
  • Thorsten Lorenzen
    Use the option --verbose, or -v for short.
    Thanks and regards,
    -George
    TI C/C++ Compiler Forum Moderator
    Please click This Resolved My Issue on the best reply to your question
    The CCS Youtube Channel
     has short how-to videos
    The
    Compiler Wiki answers most common questions
    Track an issue with SDOWP. Enter your bug id in the Search box.
  • In reply to George Mock:
    Thank you very much George. don't know why however didn't get notified of your response by mail. Any idea why this is happened? Just i case you know.
    Many thanks again
    Thorsten
  • In reply to Thorsten Lorenzen:
    Thorsten Lorenzen
    Make sure you forum e-mail settings are what you expect.  In the upper right corner, click on your avatar.  Then click on Settings | E2E email preferences.  If that all looks right, then I don't know what happened.
    Thanks and regards,
    -George
    The
    Hi George, thanks again for your help.
    1. Yes the options you mentioned for armofd.exe worked out very well.
    2. Thanks for referring to the preferences. Lately, I added notification. Now I'm notified over email. So no reason to miss responses from you again.
    Many thanks again.
    Happy new year
    Thorsten
