Compiler/MSP430F5310: #10229-D output section ".data" refers to load symbol "_nop" and hence cannot be compressed... ==> CCS 6.2, MSP430F5310, compiler 16.9.1
Part Number: MSP430F5310
I am getting the following error:
#10229-D output section ".data" refers to load symbol "_nop" and hence cannot be compressed; compression "lzss" is ignored
I found this link where George hints at the underpinnings of the issue:
https://e2e.ti.com/support/development_tools/compiler/f/343/t/293073
As he stated in that post, it's no big deal if you code fits into the flash.
However, there is the rub; My code does not fit into flash. I would like to get the compression working to see if my code will fit.
Is there any way to figure out what is causing this?
Also, I am linking in an array that is 0x2000 bytes. It does not need to be accessed in real-time. It is a backup bootloader image if it needs to be programmed. So, at application run-time, it is dead-weight. It would be great if the lzss compression could be applied to this array at compile\link. I would need access to the decompression routine. Also, can the decompression operation on sections of the blob, say 1K at a time as there is not enough RAM left for the whole image.
Jim
    This older forum thread lays out all of the details.  Fair warning: It is a long read, and quite detailed.  That thread discusses the problem with regard to the TI ARM compiler tools.  But the issue is the same for all TI compiler tools, including MSP430.  To apply the knowledge in that thread to your particular case, I tried and failed to reproduce your problem.  The best way for me to reproduce your problem is for you to submit your CCS project.  Please see this post on how to do that.  If you are not willing to do that, then at least attach the linker command file(s) to your next post, and show all the build options exactly as the linker sees them.  I might be able to reproduce it with that.
    Start with the section of the MSP430 assembly tools manual titled Linker-Generated Copy Tables.  Pay particular attention to the sub-section titled Compression.
    I don't think so.  The granularity of control is a single output section.  A single array cannot somehow span across multiple output sections.
    Thanks and regards,
    -George
    Here's the TL;DR for that thread:
    the real problem is that in the linker command file, the section ".cinit" is being placed inside a group with sections that it refers to.  This is problematic.  .cinit should not be placed in a group with any section that will be initialized at startup.
    In your linker command file, make sure that .cinit is not in any GROUP, and tell us if you still have this problem.
  • Hi George,
    Thanks for all the info. It will take a look at it.
    I will look into sending you the entire CCS project. In the mean time, I have attached the linker command file to this post. The forum does not allow upload of .cmd files so I have changed the extension to .txt.
    You are correct, I had the .const inside a group. I took it out of the group but I still get the same error. Both .cmd files are attached to this post.
    Here is the exact error message:
    Description    Resource    Path    Location    Type
    #10229-D output section ".data" refers to load symbol "_nop" and hence cannot be compressed; compression "lzss" is ignored    SynCapBdApp             C/C++ Problem
    Jim
    /* Copyright (c) 2013, Texas Instruments Incorporated                           */
    /*  All rights reserved.                                                        */
    /*  Redistribution and use in source and binary forms, with or without          */
    /*  modification, are permitted provided that the following conditions          */
    /*  are met:        */
    /*  *  Redistributions of source code must retain the above copyright           */
    /*     notice, this list of conditions and the following disclaimer.            */
    /*  *  Redistributions in binary form must reproduce the above copyright        */
    /*     notice, this list of conditions and the following disclaimer in the      */
    /*     documentation and/or other materials provided with the distribution.     */
    /*  *  Neither the name of Texas Instruments Incorporated nor the names of      */
    /*     its contributors may be used to endorse or promote products derived      */
    /*     from this software without specific prior written permission.            */
    /*  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" */
    /*  AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,       */
    /*  THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR      */
    /*  PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR            */
    /*  CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,       */
    /*  EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,         */
    /*  PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; */
    /*  OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,    */
    /*  WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR     */
    /*  OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,              */
    /*  EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.                          */
    /* lnk_msp430f5310.cmd - LINKER COMMAND FILE FOR LINKING MSP430F5310 PROGRAMS     */
    /*   Usage:  lnk430 <obj files...>    -o <out file> -m <map file> lnk.cmd     */
    /*           cl430  <src files...> -z -o <out file> -m <map file> lnk.cmd     */
    /* These linker options are for command line linking only.  For IDE linking,  */
    /* you should set your linker options in Project Properties                   */
    /* -c                                               LINK USING C CONVENTIONS  */
    /* -stack  0x0100                                   SOFTWARE STACK SIZE       */
    /* -heap   0x0100                                   HEAP AREA SIZE            */
    /* SPECIFY THE SYSTEM MEMORY MAP                                            */
    MEMORY
        SFR                     : origin = 0x0000, length = 0x0010
        PERIPHERALS_8BIT        : origin = 0x0010, length = 0x00F0
        PERIPHERALS_16BIT       : origin = 0x0100, length = 0x0100
        INFOA                   : origin = 0x1980, length = 0x0080
        INFOB                   : origin = 0x1900, length = 0x0080
        INFOC                   : origin = 0x1880, length = 0x0080
        INFOD                   : origin = 0x1800, length = 0x0080
        RAM_VECTORS             : origin = 0x1C00, length = 0x0200 /* 0x80 vectors 32-bits each BR instruction(16) + address(16) */
        RAM                     : origin = 0x1E00, length = 0x1400
        RAM_WRITETOFLASH        : origin = 0x3200, length = 0x0200
        FLASH                   : origin = 0x8000, length = 0x5FE0
        FLASH_APPSWVER          : origin = 0xDFE0, length = 0x0010
        FLASH_APPXSUM           : origin = 0xDFF0, length = 0x0010
        FLASH_BOOTLOADER        : origin = 0xE000, length = 0x1F80
        FLASH_VECTORS_RSVD      : origin = 0xFF80, length = 0x0052
        FLASH_VECTORS           : origin = 0xFFD2, length = 0x002C
        RESET                   : origin = 0xFFFE, length = 0x0002
        Forcing vectors, EXCEPT for RESET, to point to RAM
        addresses using FLASH_VECTORS & FLASHVECT_SEG. Not using
        default dynamic linking to functions. Original
        implementation saved here for reference.
        INT00                   : origin = 0xFF80, length = 0x0002
        INT01                   : origin = 0xFF82, length = 0x0002
        INT02                   : origin = 0xFF84, length = 0x0002
        INT03                   : origin = 0xFF86, length = 0x0002
        INT04                   : origin = 0xFF88, length = 0x0002
        INT05                   : origin = 0xFF8A, length = 0x0002
        INT06                   : origin = 0xFF8C, length = 0x0002
        INT07                   : origin = 0xFF8E, length = 0x0002
        INT08                   : origin = 0xFF90, length = 0x0002
        INT09                   : origin = 0xFF92, length = 0x0002
        INT10                   : origin = 0xFF94, length = 0x0002
        INT11                   : origin = 0xFF96, length = 0x0002
        INT12                   : origin = 0xFF98, length = 0x0002
        INT13                   : origin = 0xFF9A, length = 0x0002
        INT14                   : origin = 0xFF9C, length = 0x0002
        INT15                   : origin = 0xFF9E, length = 0x0002
        INT16                   : origin = 0xFFA0, length = 0x0002
        INT17                   : origin = 0xFFA2, length = 0x0002
        INT18                   : origin = 0xFFA4, length = 0x0002
        INT19                   : origin = 0xFFA6, length = 0x0002
        INT20                   : origin = 0xFFA8, length = 0x0002
        INT21                   : origin = 0xFFAA, length = 0x0002
        INT22                   : origin = 0xFFAC, length = 0x0002
        INT23                   : origin = 0xFFAE, length = 0x0002
        INT24                   : origin = 0xFFB0, length = 0x0002
        INT25                   : origin = 0xFFB2, length = 0x0002
        INT26                   : origin = 0xFFB4, length = 0x0002
        INT27                   : origin = 0xFFB6, length = 0x0002
        INT28                   : origin = 0xFFB8, length = 0x0002
        INT29                   : origin = 0xFFBA, length = 0x0002
        INT30                   : origin = 0xFFBC, length = 0x0002
        INT31                   : origin = 0xFFBE, length = 0x0002
        INT32                   : origin = 0xFFC0, length = 0x0002
        INT33                   : origin = 0xFFC2, length = 0x0002
        INT34                   : origin = 0xFFC4, length = 0x0002
        INT35                   : origin = 0xFFC6, length = 0x0002
        INT36                   : origin = 0xFFC8, length = 0x0002
        INT37                   : origin = 0xFFCA, length = 0x0002
        INT38                   : origin = 0xFFCC, length = 0x0002
        INT39                   : origin = 0xFFCE, length = 0x0002
        INT40                   : origin = 0xFFD0, length = 0x0002
        INT41                   : origin = 0xFFD2, length = 0x0002
        INT42                   : origin = 0xFFD4, length = 0x0002
        INT43                   : origin = 0xFFD6, length = 0x0002
        INT44                   : origin = 0xFFD8, length = 0x0002
        INT45                   : origin = 0xFFDA, length = 0x0002
        INT46                   : origin = 0xFFDC, length = 0x0002
        INT47                   : origin = 0xFFDE, length = 0x0002
        INT48                   : origin = 0xFFE0, length = 0x0002
        INT49                   : origin = 0xFFE2, length = 0x0002
        INT50                   : origin = 0xFFE4, length = 0x0002
        INT51                   : origin = 0xFFE6, length = 0x0002
        INT52                   : origin = 0xFFE8, length = 0x0002
        INT53                   : origin = 0xFFEA, length = 0x0002
        INT54                   : origin = 0xFFEC, length = 0x0002
        INT55                   : origin = 0xFFEE, length = 0x0002
        INT56                   : origin = 0xFFF0, length = 0x0002
        INT57                   : origin = 0xFFF2, length = 0x0002
        INT58                   : origin = 0xFFF4, length = 0x0002
        INT59                   : origin = 0xFFF6, length = 0x0002
        INT60                   : origin = 0xFFF8, length = 0x0002
        INT61                   : origin = 0xFFFA, length = 0x0002
        INT62                   : origin = 0xFFFC, length = 0x0002
    /* SPECIFY THE SECTIONS ALLOCATION INTO MEMORY                              */
    SECTIONS
        .bss        : {} > RAM                /* GLOBAL & STATIC VARS              */
        .data       : {} > RAM                /* GLOBAL & STATIC VARS              */
        .sysmem     : {} > RAM                /* DYNAMIC MEMORY ALLOCATION AREA    */
        .stack      : {} > RAM (HIGH)         /* SOFTWARE SYSTEM STACK             */
        .boot > 0x8000
            -l rts*.lib<boot_special.obj > (.text)
        GROUP
            .text       : {}               /* CODE                              */
            .cinit      : {}               /* INITIALIZATION TABLES             */
            .const      : {}               /* CONSTANT DATA                     */
            .pinit      : {}               /* C++ CONSTRUCTOR TABLES            */
            .init_array : {}               /* C++ CONSTRUCTOR TABLES            */
            .mspabi.exidx : {}             /* C++ CONSTRUCTOR TABLES            */
            .mspabi.extab : {}             /* C++ CONSTRUCTOR TABLES            */
        } load = FLASH
        /*---[RUN FROM RAM]----------------------------------------*/
        RAMVECT_SEG : load = FLASH, run = RAM_VECTORS, table(_ramvector)
        .ovly : {} > FLASH
        WRITETOFLASH_SEG   : {} load = FLASH, run = RAM_WRITETOFLASH, table(_writetoflash)
    	.ovly {} > FLASH
        .infoA     : {} > INFOA              /* MSP430 INFO FLASH MEMORY SEGMENTS */
        .infoB     : {} > INFOB
        .infoC     : {} > INFOC
        .infoD     : {} > INFOD
        .cio          : {} > RAM            /* C I/O BUFFER                      */
        .reset        : {} > RESET          /* MSP430 RESET VECTOR               */
        FLASHVECT_SEG : {} > FLASH_VECTORS
        APPSWVER_SEG  : {} > FLASH_APPSWVER
        /* MSP430 INTERRUPT VECTORS          */
        .int00       : {}               > INT00
        .int01       : {}               > INT01
        .int02       : {}               > INT02
        .int03       : {}               > INT03
        .int04       : {}               > INT04
        .int05       : {}               > INT05
        .int06       : {}               > INT06
        .int07       : {}               > INT07
        .int08       : {}               > INT08
        .int09       : {}               > INT09
        .int10       : {}               > INT10
        .int11       : {}               > INT11
        .int12       : {}               > INT12
        .int13       : {}               > INT13
        .int14       : {}               > INT14
        .int15       : {}               > INT15
        .int16       : {}               > INT16
        .int17       : {}               > INT17
        .int18       : {}               > INT18
        .int19       : {}               > INT19
        .int20       : {}               > INT20
        .int21       : {}               > INT21
        .int22       : {}               > INT22
        .int23       : {}               > INT23
        .int24       : {}               > INT24
        .int25       : {}               > INT25
        .int26       : {}               > INT26
        .int27       : {}               > INT27
        .int28       : {}               > INT28
        .int29       : {}               > INT29
        .int30       : {}               > INT30
        .int31       : {}               > INT31
        .int32       : {}               > INT32
        .int33       : {}               > INT33
        .int34       : {}               > INT34
        .int35       : {}               > INT35
        .int36       : {}               > INT36
        .int37       : {}               > INT37
        .int38       : {}               > INT38
        .int39       : {}               > INT39
        .int40       : {}               > INT40
        RTC          : { * ( .int41 ) } > INT41 type = VECT_INIT
        PORT2        : { * ( .int42 ) } > INT42 type = VECT_INIT
        TIMER2_A1    : { * ( .int43 ) } > INT43 type = VECT_INIT
        TIMER2_A0    : { * ( .int44 ) } > INT44 type = VECT_INIT
        USCI_B1      : { * ( .int45 ) } > INT45 type = VECT_INIT
        USCI_A1      : { * ( .int46 ) } > INT46 type = VECT_INIT
        PORT1        : { * ( .int47 ) } > INT47 type = VECT_INIT
        TIMER1_A1    : { * ( .int48 ) } > INT48 type = VECT_INIT
        TIMER1_A0    : { * ( .int49 ) } > INT49 type = VECT_INIT
        DMA          : { * ( .int50 ) } > INT50 type = VECT_INIT
        LDO_PWR      : { * ( .int51 ) } > INT51 type = VECT_INIT
        TIMER0_A1    : { * ( .int52 ) } > INT52 type = VECT_INIT
        TIMER0_A0    : { * ( .int53 ) } > INT53 type = VECT_INIT
        ADC10        : { * ( .int54 ) } > INT54 type = VECT_INIT
        USCI_B0      : { * ( .int55 ) } > INT55 type = VECT_INIT
        USCI_A0      : { * ( .int56 ) } > INT56 type = VECT_INIT
        WDT          : { * ( .int57 ) } > INT57 type = VECT_INIT
        TIMER0_B1    : { * ( .int58 ) } > INT58 type = VECT_INIT
        TIMER0_B0    : { * ( .int59 ) } > INT59 type = VECT_INIT
        COMP_B       : { * ( .int60 ) } > INT60 type = VECT_INIT
        UNMI         : { * ( .int61 ) } > INT61 type = VECT_INIT
        SYSNMI       : { * ( .int62 ) } > INT62 type = VECT_INIT
    /* INCLUDE PERIPHERALS MEMORY MAP                                           */
    -l msp430f5310.cmd
    /*  are met:        */
    MEMORY
    SECTIONS
        .boot > 0x8000
        GROUP
        } load = FLASH
        .ovly : {} > FLASH
    	.ovly {} > FLASH
        .infoB     : {} > INFOB
        .infoC     : {} > INFOC
        .infoD     : {} > INFOD
        .int00       : {}               > INT00
        .int01       : {}               > INT01
        .int02       : {}               > INT02
        .int03       : {}               > INT03
        .int04       : {}               > INT04
        .int05       : {}               > INT05
        .int06       : {}               > INT06
        .int07       : {}               > INT07
        .int08       : {}               > INT08
        .int09       : {}               > INT09
        .int10       : {}               > INT10
        .int11       : {}               > INT11
        .int12       : {}               > INT12
        .int13       : {}               > INT13
        .int14       : {}               > INT14
        .int15       : {}               > INT15
        .int16       : {}               > INT16
        .int17       : {}               > INT17
        .int18       : {}               > INT18
        .int19       : {}               > INT19
        .int20       : {}               > INT20
        .int21       : {}               > INT21
        .int22       : {}               > INT22
        .int23       : {}               > INT23
        .int24       : {}               > INT24
        .int25       : {}               > INT25
        .int26       : {}               > INT26
        .int27       : {}               > INT27
        .int28       : {}               > INT28
        .int29       : {}               > INT29
        .int30       : {}               > INT30
        .int31       : {}               > INT31
        .int32       : {}               > INT32
        .int33       : {}               > INT33
        .int34       : {}               > INT34
        .int35       : {}               > INT35
        .int36       : {}               > INT36
        .int37       : {}               > INT37
        .int38       : {}               > INT38
        .int39       : {}               > INT39
        .int40       : {}               > INT40
    -l msp430f5310.cmd
  • The problem is not .const, it is .cinit.
