Part Number: PROCESSOR-SDK-AM335X
Other Parts Discussed in Thread: AM3359, SYSBIOS, TEST2
Setup:
AM3359 ICEv2 application
Compiler version TI v5.1.11
XDC 3.25.4.88
SYSBIOS 6.35.4.50
Industrial SDK: am335x_sysbios_ind_sdk_1.1.0.4
Hi, I am working on moving some critical section sysbios (KNL and HWI APIs) from DDR to SRAM as mentioned in this Wiki link (attached new linker command)
However, I need to test my changes using an SD card (customer's test application requires multiple resets). When running postbuild scripts the final binary is huge, about 1GB! .
I have been trying different settings for stripping unnecessary information and debug information but the size is mainly the same. Below examples of what I have tried:
Test1: arm-none-eabi-objcopy.exe -O binary -R .ARM.exidx -R .ARM.extab -R .debug_aranges -R .debug_info -R .debug_abbrev -R debug_pubnames -R debug_aranges -R debug_pubtypes -R .debug_line -R .debug_frame -R .debug_str -R .debug_loc -R .debug_ranges app.out app.bin
Test2: arm-none-eabi-objcopy.exe -O binary --strip-all --strip-debug --strip-unneeded app.out app.bin
Test3: arm-none-eabi-objcopy.exe -O binary -j .init -j ti.sysbios.family.arm.a8.mmuTableSection -j .knl -j .hwi -j .sysbios -j .stack -j .bss -j .neardata -j rodata -j .cinit -j .args -j .vecs -j xdc.meta -j .text -j .const.1 -j cost.2 -j .data app.out app.bin
I read online that the issue is the "hole" between memory sections in this case DDR and SRAM.
Question to the compiler experts:
- Is there any trick that I can use in order to take out the "hole"?
- is there any objcopy configuration that I can try?
- Any other idea is also welcome =)
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/81/am335x.cmd
Thank you,
Paula
