CCS: Error in CCSv6
Prodigy 10 points
Dear,
I am trying to load compiled code in simulink in code composter studio v6 (.OUT file), after having done all the settings and throws me the following error:
C28xx: Loader: One or more sections of your program falls nto a memory region that is not writable. These regions will not actually be written to the target. Check your linker configuration and/or memory map.
  • I'm using the XDS100v3
  • Ccsv6
  • TI card model TMS320P28016
If you can help me I would appreciate it
  • Guru 134270 points
    Nicolas,
    It would be best to contact The MathWorks.  I suspect that the issue is that the linker command file used by Simulink doesn't match with the memory layout of the TMS320F28016.
    Here is the memory map from the data sheet for the device:
    The error you are getting is basically CCS saying that the program is trying to load to a memory address that as far as CCS is concerned is not writable.
    John
    If my reply answers your question please click the "This resolved my issue" button
  • In reply to JohnS:
    Hi Nicolas,
    JohnS could very well be correct here. Please contact MathWorks Technical Support for assistance.
    -Brian
    Brian McKay  |  Technical Marketing  |  www.mathworks.com
