Compiler: Syntax to compile assembly code embedded in C with TI compiler
Guru* 95265 points
Champs,
I have a .c file with several embedded assembly code like this:
unsigned int get_clock(void)
unsigned int cc;
__asm__ __volatile__ ("mrc p15, 0, %0, c9, c13, 0\t\n" : "=r"(cc));
return cc;
when compiling with ARM GNU compiler, there is no issue. When compile with TI 17.3.LTS compiler, there is syntax error:
 error #18: expected a ")"
What is the correct syntax for this?
Regards, Eric
