Other Parts Discussed in Thread: TMS570LS3137, TMS570LS1227
I rewrited openocd config for launchxl-rm46 board, because config in repo is invalid.
adapter_khz 1500
source [find interface/cmsis-dap.cfg]
#source [find interface/xds110.cfg]
transport select jtag
set CHIPNAME rm46
set DAP_TAPID 0x2B95502F
set JRC_TAPID 0x2B95502F
adapter_khz 1500
if { [info exists CHIPNAME] } {
set _CHIPNAME $CHIPNAME
} else {
set _CHIPNAME tms570
if { [info exists ENDIAN] } {
set _ENDIAN $ENDIAN
} else {
set _ENDIAN big
# TMS570 has an ICEpick-C on which we need the router commands.
source [find target/icepick.cfg]
# Main DAP
# DAP_TAPID should be set before source-ing this file
if { [info exists DAP_TAPID] } {
set _DAP_TAPID $DAP_TAPID
jtag newtap $_CHIPNAME cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id $_DAP_TAPID -disable
jtag configure $_CHIPNAME.cpu -event tap-enable "icepick_c_tapenable $_CHIPNAME.jrc 0"
# ICEpick-C (JTAG route controller)
# JRC_TAPID should be set before source-ing this file
if { [info exists JRC_TAPID] } {
set _JRC_TAPID $JRC_TAPID
set _JRC_TAPID2 0x0B7B302F
set _JRC_TAPID3 0x0B95502F
set _JRC_TAPID4 0x0B97102F
set _JRC_TAPID5 0x0D8A002F
set _JRC_TAPID6 0x2B8A002F
set _JRC_TAPID7 0x2D8A002F
set _JRC_TAPID8 0x3B8A002F
set _JRC_TAPID9 0x3D8A002F
jtag newtap $_CHIPNAME jrc -irlen 6 -ircapture 0x1 -irmask 0x3f \
-expected-id $_JRC_TAPID \
-expected-id $_JRC_TAPID2 \
-expected-id $_JRC_TAPID3 \
-expected-id $_JRC_TAPID4 \
-expected-id $_JRC_TAPID5 \
-expected-id $_JRC_TAPID6 \
-expected-id $_JRC_TAPID7 \
-expected-id $_JRC_TAPID8 \
-expected-id $_JRC_TAPID9 \
-ignore-version
jtag configure $_CHIPNAME.jrc -event setup "jtag tapenable $_CHIPNAME.cpu"
jtag configure $_CHIPNAME.jrc -event post-reset "runtest 100"
# Cortex-R4 target
set _TARGETNAME $_CHIPNAME.cpu
dap create $_CHIPNAME.dap -chain-position $_CHIPNAME.cpu
target create $_TARGETNAME cortex_r4 -endian $_ENDIAN \
-dap $_CHIPNAME.dap -coreid 0 -dbgbase 0x00001003
# TMS570 uses quirky BE-32 mode
#$_TARGETNAME dap ti_be_32_quirks 1
gdb_breakpoint_override hard
$_TARGETNAME configure -event gdb-attach {
cortex_r4 dbginit
reset halt
wait_halt
$_CHIPNAME.cpu arp_halt
wait_halt
$_TARGETNAME configure -event "reset-assert" {
global _CHIPNAME
# assert warm system reset through ICEPick
icepick_c_wreset $_CHIPNAME.jrc
openocd run correctly, but when i try to make target halt i see
Error: Timeout waiting for halt
when i try reset halt i see
Info : JTAG tap: rm46.jrc tap/device found: 0x2b95502f (mfg: 0x017 (Texas Instruments), part: 0xb955, ver: 0x2)
Info : JTAG tap: rm46.cpu enabled
Warn : rm46.cpu: ran after reset and before halt ...
in procedure 'reset'
in procedure 'ocd_bouncer'
may be i have mistake?
