I'm using Compiler version TI v16.9.7.LTS for compatibility reasons; I don't know if I can upgrade to a later version.
In one file, I have declared 5 static variables at file scope. Only space is being allocated for 4 of the variables. If I change the order of the declarations, a different set of the 4 (out of the 5) variables are allocated.
I have tried a number of workarounds (such as changing the order of the declarations, adding more static variables, etc.), but I have not yet found a workaround.
Is this a known issue? Is there a workaround?
Thanks in advance!
